1998 GMC Sierra Oil pan
1998 GMC SIERRA
10,900 MILES • V8 • 4WD • AUTOMATIC
DCHAMBERS1
my oil pan started leaking right through the pan rotted out. I have a pan and gasket but seems like a big job to remove old pan being as 4wd is in the way. what do i need to remove to do this job? jack the engine, remove cv joint? thanks
Aug 29, 2008 at 7:25 PM
BADBO
  • 35 POSTS
You didn't say which engine it had. This is for 4.3L engine
Un bolt all these or remove
Oil pan skid plate bolts and plate, if equipped
Engine oil and filter
Crossmember bolts and bar
On 4WD, the front differential carrier
Battery cable bracket bolts.
Starter
Transmission cover
Positive battery cable clip bolt
Oil level sensor electrical connector
Transmission
Oil level sensor and discard
Oil pan bolts and oil pan
Oil pan gasket
badbo
Aug 29, 2008 at 7:42 PM
