the engine runs hot. I ran low on coolant last week so I filled it up,now it runs hot all the time. Before, it ran half way between 100 and 210degrees. I have replaced the thermostat,water pump checked the hoses (no leaks) and replaced the temperature sending unit. I dont know what else to do . Can you help me with this problem? thank you
Feb 27, 2010 at 7:54 PM
