1998 GMC Sierra
SUMMERFIELD
1998 GMC Sierra V8 Four Wheel Drive Automatic
My truck sputters and bogs down when I step on the gas like when I am passing another vehicle or when i am going up hills. Fuel pump is fairly new along with spark plugs, cap and rotor. What could be the problem?
Sep 6, 2010 at 2:52 PM
  • 75,988 POSTS
Possible causes:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Sep 6, 2010 at 4:10 PM
