1998 GMC Sierra
PAT LUNDRIGAN
Engine Mechanical problem
1998 GMC Sierra 6 cyl Two Wheel Drive Automatic
cranks but will not start when hot
Nov 6, 2010 at 2:05 AM
HMAC300
  • 48,601 POSTS
if your service engine light isn't on then it could be the crank sensor or cam sensor. or the fuel pump. you need to check the fuel pressure. and the sensors for ohms as they may be to high. Also check yoru fuel pupmp harness as they had a problem which would give you an indication of low fuel pressure.
Nov 7, 2010 at 10:21 AM
