1997 GMC Sierra Transmission Whines
150,000 MILES • V8 • 2WD • AUTOMATIC
RUSS07
The transmission on my GMC pick up has an intermittent whine. I asked a mechanic about changing the fluid, and he told me that if it had not been changed in the last 40K miles that it would most likely destroy the transmission. Can I get someone to confirm this for me? I mean a testimonial or first-hand knowledge.
Now, I do know that a bad catalytic converter can result in the same symptoms. Can anyone advise me as to a secure course of action?
rrw
May 10, 2008 at 4:40 PM
MASTERTECHTIM
  • 4,750 POSTS
i cant confirm it but i will deny it. you must change the fluid and filter, right now!!!!! the only thing that will cause this transmission to whine is a clogged transmission oil filter. i have seen it many times. also check to make sure the pan is not pushed in from hitting something. definitely change oil and filter with a new pan gasket.
May 10, 2008 at 11:08 PM
