1997 GMC Sierra lock up
1997 GMC SIERRA
140,000 MILES • V8 • 4WD • AUTOMATIC
GJETTE
hello , iam new to the site, and must say very impressed with the service you provide for people.
when it has rained out or there is alot of moisture in the air the right rear drum brake lockes up the minute you apply any type of brake , and skreeches . you have to pick up a little speed and apply the brakes to get it to free up . then its fully operational at that point on . there is no pulling or repeat while you drive . just the first start and go. what does this sound like to you?
thank you for your attention.
garrett from nashua nh.
Mar 14, 2009 at 11:05 PM
MERLIN2021
  • 17,250 POSTS
The first thing we need to know is which rear brakes you have, disc or drum?
https://images.2carpros.com/forum/automotive_pictures/62217_GMCa_1.jpg
https://images.2carpros.com/forum/automotive_pictures/62217_gmcb_2.jpg
Mar 15, 2009 at 1:26 AM
GJETTE
they are 11 inch drum brakes.
Mar 15, 2009 at 7:12 AM
MERLIN2021
  • 17,250 POSTS
Has any recent work been done to the brakes or axles? If not remove the drum, inspect the wheel cylender, push the pistons in, do they move freely? Any leaks under the dust boots? I use a pick to inspect inside the boots, if they are OK next check the shoes, is the larger shoe at the back? All springs and hold downs in place? Next, is the axle seal leaking any rear end oil into the drum? Last chaek parking brake cable, is it frozen? Then adjust rear brakes until a slight drag is felt.
Mar 16, 2009 at 7:07 AM
GJETTE
thank you,
will check.
Mar 16, 2009 at 7:23 AM
