1997 GMC Sierra Intermittant hard shift btwn 1-2, 1870 code
150,000 MILES • V8 • 2WD • AUTOMATIC
1JS
I Have 5.7L with a 4l60e trans. It has a intermittant hard shift btwn 1-2 and a 1870 code comes up.
If this is an internal problem in the transmission, what is it and is it worth fixing? Is rebuilding better than replacement with a used one? And is this the only year that will replace my transmission? I see many low milage transmissons from later year vehicles, but not sure if they will fit.
Thanks,
Jim
Nov 7, 2010 at 1:28 AM
HMAC300
  • 48,601 POSTS
the rebuild vs recycled trans is up to you and what the cost is. Junk yards usually guarntee their trans to work. the only problem is the electrical connection that they take. they have to be the same otherwise you can run into problems trying to get your trans to work right. When it is rebuilt, every seal and clutch plate are replaced along with the torque converter. And parts that are found bad like planetary gear sets arealso replced usually with new but not always. Also if you get a trans form a junkyard and it doesn't work, then you have to pull it out and get another one. It's just if you decide to do the work yourself of replacing the trans or not.
Nov 7, 2010 at 10:14 AM
