1997 GMC Sierra checking alternater
1997 GMC SIERRA
JAZEE
Electrical problem
1997 GMC Sierra V8 Two Wheel Drive Automatic
can i check my alternater by disconnecting battery cable while engine is running?
Mar 4, 2010 at 9:02 AM
Bad idea disconnecting it can cause an overload-Use a voltmeter and read the voltage of the battery while engine is running should be 13.5-15.5 volts if the alternator is doing its job-
Mar 4, 2010 at 10:21 AM
