HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
GMC
Sierra
Drivetrain
Differential
Axle
SPONSORED LINKS
1996 GMC Sierra Torque settings
LVGJR
MEMBER
1996 GMC SIERRA
V8
4WD
AUTOMATIC
189,000 MILES
Torque setting for front axel nut
Sunday, March 7th, 2010 AT 2:54 PM
MECHANIC
173 ft lbs
SPONSORED LINKS
Sunday, March 7th, 2010 AT 4:35 PM
LVGJR
MEMBER
173 Ft lbs seems high for a axle nut use on the hub bearings
Monday, March 8th, 2010 AT 3:30 PM
MECHANIC
That came from Mit1 ondemand sorry if you disagree
Monday, March 8th, 2010 AT 3:46 PM
LVGJR
MEMBER
This is a Z71 (K1500) and this is the torque on the front axel hub nut.
Monday, March 8th, 2010 AT 4:06 PM
MECHANIC
I'm getting the same specs for this K1500
SPONSORED LINKS
Monday, March 8th, 2010 AT 6:41 PM
Please
login
or
register
to post a reply.
Related Differential Axle Content
Gmc 4x4 Front Axle
I Have A 2002 Gmc Sierra 4x4, The Front Wheels Will Not Engage When I Put It In 4wd. I Have A 2 Inch Leveling Kit On The Front Thats The...
Asked by
mistermnkim
1 ANSWER
2002
GMC SIERRA
How Do You Check For Adjustment On The Differential...
I Have A 2003 Gmc Sierra. On The Front Driver Side There Is A Differential Bearing Adjuster In The Axle Housing That May Be The Cause Of A...
Asked by
CHuggins
1 ANSWER
2003
GMC SIERRA
The Bearing In The Rear Differenenteral Went Out...
The Bearing In The Rear Differenenteral Went Out Locking The Rearend Upp Tight Cant Get To The Bolt To Pull The Pin That Holds The Axels In...
Asked by
Anonymous
1 ANSWER
2000
GMC SIERRA
Why Does Rear End Lock Up When Turning Corner And...
Rear End Locking Up
Asked by
jclews
1997
GMC SIERRA
2004 Gmc Sierra Rear End Noise
Last Week I Bought A 2004 Gmc Sierra 1500 From A Private Seller, Seemed Like A Legit Guy. Well He Said That He Had Just Had The Whole Rear...
Asked by
roland0305
2004
GMC SIERRA
VIEW MORE
SPONSORED LINKS
Rear Axle Seal Replacement
Axle Bearing and Seal Replacement
Online car repair manuals
