1996 GMC Sierra replace headlights
120,000 MILES • V8 • 4WD • AUTOMATIC
JOHN761450
you say to remove screw on top of radiator bracket cannot find any screws bolts or anything else to remove, also no size on what the nut is to remove.
Oct 12, 2010 at 9:14 AM
BLUELIGHTNIN6
  • 16,542 POSTS
if the hood is opened and you cant find the screws near the radiator support rail than you may have a different style of headlamps. if thats the case then there should be a screw near each corner of the bezel that surrounds the headlamp.
Oct 12, 2010 at 9:56 AM
JOHN761450
i have the composite lights, still no screws there
Oct 13, 2010 at 4:49 AM
BLUELIGHTNIN6
  • 16,542 POSTS
post a pic and i can help you further
Oct 13, 2010 at 5:42 AM
