1996 GMC Sierra Multi cylinder misfires
DTMORGAN99
  • 1996 GMC SIERRA
  • V8
  • 4WD
  • 327,000 MILES
To set the senerio, for several months I have been receiving a catalytic inefficiency bank 2, have been fowling #4 and #6 sparkplugs, which I belive is due to leaking valve seals, soo, id did as chiltons suggests, found tdc #1, disassembled and replaced valve guide seals for all 8 cylinders, on the motor, adjusting valves as I went along for each cylinder, truck had actually been running fine before this other than the check engine light, 17 mpg as usuall, some slight valve noise during a load and accereration, when all was said and done, engine started right off, was quite rough and less than one minute received p0300 mulitcylinder misfire, distributor was not removed, checked that all wires were installed properly on corresponding cylinder, to no avail, replaced cap, rotor, wires and plugs same outcome, thinking valve adjustment could be wrong, dont see how really, on tdc of compression stroke, did tighten rocker nuts till pushrod stopped turning then added 3/4 turn as book says, noticed when I disassembled that adjustment seemed to be without the 3/4 turn as pushrods could be turned and rockers seemed to be loose, or right at that point of no slack, have no clue what to look into to correct this other than take it to a dealer for diagnostics, rather not go there, dont think its time really for a rebuild, was a daily driver before the valve seals replacement please help , dave
Sunday, October 18th, 2009 AT 8:58 PM
JDL
  • 16,098 POSTS
Welcome to the forum, just thought. I'd want to check fuel pressure with a gage. With the spider fuel system, I always check fuel system first. They are noted for poppet valves sticking, several issues.
Monday, October 19th, 2009 AT 1:22 PM
DTMORGAN99
Even my wife asked if there was fuel pressure, wasnt the problem. Have fixed this already thanks, was actually valve clearance causing all the problem, chiltons and past experience says to tighten til snug on pushrod then add 3/4 turn, back all off a half turn from that, so was only a quarter turn and the think purrs like a kitten, did some minor adjustments with it running, put it together, and am driving on in search of 500k out of this gas motor. But thanks anyway, lol fuel pressure, think you need to be a little more serious about your diagnostics.
Tuesday, October 20th, 2009 AT 5:26 PM
