1996 GMC Sierra flooding
1996 GMC SIERRA
LABBY2698
Engine Mechanical problem
1996 GMC Sierra V8 Four Wheel Drive Automatic
starts fine after sitting for 6 hours but any sooner it will act like it wants to flood out, if I hold the foot feed down it will start. I had a buddy hook up a code reader to it and it came up with a temp code saying its not hot enough. My temp gauge shows 180. Would this also cause my torque converter to not lock up? that started happening at the same time.
Mar 19, 2010 at 3:51 PM
Hi labby2698, Welcome to 2carpros and TY for the donation
Check and test the coolant temperature sensor-acting like its flooding out could be injectors and fuel pressure regualtor leaking, to inlcude excessive fuel pressure due to clogged return line.
BTW some manufacturers use the coolant temperature sensor to control the overdrive operation of the transmission.
Mar 19, 2010 at 4:14 PM
LABBY2698
has a new updated spider and the fuel pressure is 58lbs. and doesnt leakdown for about 30 min, is there 2 sesors for the coolant? 1 for the gauge and 1 for the ecm?
Mar 19, 2010 at 5:01 PM
Yes sir
The coolant temperature sensor is located on top right front of engine near thermostat housing
and the coolant temperature sending gauge/switch on front of left cylinder head. Sorry no pic available
Mar 19, 2010 at 5:12 PM
