i NEED TO REPLACE THE WINDOW LIFT MOTOR.HOW DO i REMOVE THE WINDOW
May 17, 2009 at 2:44 AM
DR LOOT
✓Experienced Mechanic
replacing window regulators can be very tough especially on the truck you're working on, you will need to unbolt the entire inside of the door support, or with a drill removed the rivits not hold the motor to the support, you better purchasing manual to help you.
