1996 GMC Sierra corrosion in distributer cap
118,000 MILES • V8 • 4WD • AUTOMATIC
123CHRIS321
HI., I have had 3 distributer caps fail due to corrosion build up in the last 2 years the last 2 replacements were AC DELCO.
WHY?
Feb 3, 2009 at 11:34 PM
  • 110,248 POSTS
Hi:
It is unusuall for that to happen. Moisture will cause it. They make a product that sprays on a water tight seal. You may want to try it. Also, make sure that water isn't getting on it as a result of a bad seal on the hood.
Feb 5, 2009 at 7:09 AM
