1995 GMC Sierra Possible short
149,000 MILES • V8 • 4WD • AUTOMATIC
STEPHENCB79
I believe I have a short. It started with my radio powering off, then back on. Then it included my power windows, and as of this morning, it included my ignition. I am not sure where those items would come together other than at the fuse panel. Any suggestions?
Oct 16, 2009 at 6:27 AM
JDL
  • 16,098 POSTS
welcome, might be a problem with ignition switch, you can check feed to and from the switch. Use a testlite, check maxi fuse 5 and 6, 50 and 40 amp, under hood fuse block. Those circuit should be hot all the time. My info shows two red wires that carry voltage to the ignition switch, check for voltage. then we would check the feed circuit from the switch. The power window circuit breaker goes hot when you turn on the key.
Oct 16, 2009 at 9:28 AM
STEPHENCB79
It was the ignition switch FYI
Oct 16, 2009 at 4:40 PM
