1994 GMC Sierra Why does transmission shift sometimes and n
1994 GMC SIERRA
200,000 MILES • 6 CYL • 2WD • AUTOMATIC
DOOGIE06
Transmission will sometimes shift out of second into third and other times not. I had the computer scanned and there were no codes to read. Everything is A okay. I know it is a electrical problem but where does one start to look. What should the volt reading be on the VSS. The reading I had was 0.5 volts. And some one has also suggested the ignition switch on column, (not the lock cylinder). Complex by problem. Any suggestions.
Jul 22, 2010 at 12:15 AM
KHLOW2008
  • 41,814 POSTS
Hi doogie06,
Thank you for the donation.
Which engine and transmission variant do you have?
Jul 22, 2010 at 12:46 AM
DOOGIE06
Engine is a 6 cylinder 4.3
Transmiision is 4L60E or also known as M30.
Jul 23, 2010 at 3:00 AM
KHLOW2008
  • 41,814 POSTS
The reading for the VSS should be 12 volts.
The output from PCM VSS sensor should vary between 0 to 5 volts.
Where did you test the voltage from?
Jul 23, 2010 at 4:05 AM
