1994 GMC Sierra replacing the front fenders
KAYJAYJURY
1994 GMC Sierra 6 cyl Four Wheel Drive Automatic
I need instructions on how to replace my front fenders.
Apr 3, 2010 at 5:05 AM
  • 110,248 POSTS
Basically, there are a bunch of bolts that need removed. First, lift the hood and remove the bolts on top of the fender. Next, unbolt the inner fender. You will also have bolts on the undersids of the fender near the door and between the door and fender. You will also need to remove the head light assembly you access the bolts behind there as well as you may have to remove the cowl to get to a bolt there.
Like I said, it's just a bunch of bolts that need to come off.
Apr 3, 2010 at 8:14 AM
