1993 GMC Sierra instrement cluster
1993 GMC SIERRA
106,000 MILES • V8 • 4WD • AUTOMATIC
HAMMER124
my battery fell out of my truck and shorted the alternator and now my guages go up and down and all around tac jumps speedodomer jumps and the radio goes out especially when i turn on the directional i have replaced the battery and alternator but the gauges still go nuts
May 22, 2010 at 9:10 AM
CARADIODOC
  • 34,381 POSTS
Hi hammer124. Welcome to the forum. If possible, measure the battery voltage with a cheap digital voltmeter while the problem is occurring. It must be between 13.75 and 14.75 volts when the engine is running.
Check the small black wire from the battery negative cable where it bolts to the body. Be sure there is no break in that wire.
caradiodoc
May 22, 2010 at 9:24 AM
