Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
GMC
Sierra
Engine
MAP Sensor
Replace/Remove
1992 GMC Sierra idles rough
1992 GMC SIERRA
300,000 MILES • V8 • 4WD • AUTOMATIC
TESANATOR
MEMBER
1 POST
i changed plugs plug wires cap rotor map sensor egr but runs the same when reved and held there sounds good but idles as if it has a miss.
Nov 16, 2008 at 1:28 PM
LEGITIMATE007
Experienced Mechanic
I would check the idle air control valve and replace if necessary,check map sensor too,for good measure
Nov 16, 2008 at 1:47 PM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
