1992 GMC Sierra fuel trouble
MIKE MORENO
Engine Mechanical problem
1992 GMC Sierra V8 Two Wheel Drive Automatic
my truck starts up fine but dies after 30 sec. or less , you put gas in the carb and it stays on longer, i give it gas and it dies.
Aug 22, 2008 at 5:31 AM
HOBOTRUCK
Im having the exact same problem with the same make and model. I have checked spark (replaced plugs), replaced fuel filter, and fuel pump "sounds" as though it is active. I have no clue what to do now!
Sep 19, 2008 at 8:53 AM
DOCFIXIT
  • 18,828 POSTS
Check pump pressure @55psi
Sep 19, 2008 at 9:04 AM
