1991 GMC Sierra won't start
170,000 MILES • V8 • 4WD • AUTOMATIC
BINGONANNY55
my husbands truck won't start unless you spray starter fluid or gas into it then it runs good but turn it off and it will not start untill you spray it again. can you help with this problem
Jul 16, 2008 at 10:43 AM
  • 75,988 POSTS
Do you hear the fuel pump for 2secs when key at run -if not check the fuel pump relay-the oil pressure sending unit powers the pump after it starts up-there's no initial fuel pressurization-
https://images.2carpros.com/forum/automotive_pictures/12900_oil_sending_unit_and_fuel_pump_circuit_62.gif
Jul 16, 2008 at 10:53 AM
