1991 GMC Sierra runs rich, wont idle
1991 GMC SIERRA
175,000 MILES • V8 • 4WD • AUTOMATIC
BRADLYCT
My GMC will almost die and then rev up, and miss badly on acceleration. I have tried to troubleshoot it and have not made any progress. It does not bring up any codes, I have changed fuel filter, plugs, wires, rotor, dist cap, o2 sensor, coolant temp sensor, throttle pos sensor, idle speed module, intake manifold gasket, rebuilt throttle body, replaced injectors, and fuel pump. When it runs the intake manifold gets alot of excess fuel sitting in the bottom. I have taken the truck to different shops and they are at a loss. Anything would help, Thanks
Dec 4, 2008 at 8:42 PM
Running rich could be one of the following. Possible causes include a bad O2 sensor, excessive fuel pressure (bad fuel pressure regulator or plugged return line), leaky fuel injectors, dirty air filter or restricted air inlet, or a defective coolant sensor that prevents the engine management system from going into closed loop mode.
Dec 4, 2008 at 8:50 PM
