1991 GMC Sierra Engine runs rough
75,000 MILES • V8 • 4WD • AUTOMATIC
TPFORREST
When engine is first started it idles fine. When accelerator is engaged the engine spurts and sputters as if it is getting too much or not enough fuel. When the engine is warm it runs smoother but there is always a hesitation when the gas pedal is first depressed. Other issues that may be related include a significant amount of carbon from the tail pipe when the truck is at an idle and dirty oil immediately after an oil change.[img:bd738d8460]http://www.2carpros.com/forum/automotive_pictures/194244_S2020001_1.jpg[/img:bd738d8460]
May 25, 2008 at 4:34 PM
LEGITIMATE007
  • 5,121 POSTS
I would do a good throttle body (bore) cleaning first , along with throttle plate and cleaning the linkage also replace air filter if dirty and pcv valve. and we'll take it from there. also whens the last times you changed the plugs and wires.? that could be the issue too. these are all the minor things that should be addressed before. we can go on
May 26, 2008 at 2:29 AM
