Welcome to the forum, your lower brake lites and turn signal use the same bulb filament just not at the same time. I'd have to check voltage and ground at the rear. Brown wire is voltage for tail lights, yellow is voltage for brake/turn, black is ground.
SPONSORED LINKS
Tuesday, November 17th, 2009 AT 3:42 PM
