had to replace slave unit then also put on new master again, having problem bleeding out
Sep 11, 2010 at 8:12 AM
WRENCHTECH
✓Experienced Mechanic
They can be very difficult because the bleeder is at the bottom and the air rises to the top. You may need a pressure bleeder to get all the air out. Sometimes just continuously pumping the pedal will work the air out of the top.
Sep 11, 2010 at 8:28 AM
