1989 GMC Sierra 89 chevy TBI
GPYOUNKER
Engine Performance problem
1989 GMC Sierra V8 Four Wheel Drive Automatic 80;000 miles
When you first start and run the engine it runs fine for about 10 min.Then it goes haywire dumping to much gas into the TBI There is a loud air sound comming out of TBI exhaust gas burnes your eyes very rich, could it be fuel pressure Regulator Or what els can i check.
Thank you Glen
Jun 11, 2008 at 5:19 AM
BMRFIXIT
  • 19,053 POSTS
Hi Glen
it is very possible that the fuel pressure is bad and you need to have it checked
I would also recommend checking the EGR valve and its operation
check and or replace MAP sensor and its vacuum line
check for codes if possible
Jun 11, 2008 at 2:16 PM
