1988 GMC Sierra fuel?
98,000 MILES • V8 • 4WD • MANUAL
CHINVAT3
I have changed the fuel pump 8 times, the system blows out the fuel pump every two weeks. I have changed the tank, lines, distributor, spark plugs, and wires, and always the same way it dies, it back fire's, then chokes, then dead...........help!!!!!!!!!!!
Mar 20, 2010 at 2:53 PM
  • 110,248 POSTS
Hi:
Is the fuel pump actually bad when you remove it? Have you been using the same type of pump?
Apr 3, 2010 at 9:07 AM
