1988 GMC Sierra Brake lights, directional (front&back)
PICKUPDANGELO
  • 1988 GMC SIERRA
  • V8
  • 219,194 MILES
I bought a 1988 gmc pickup, and I am trying to get to the bottom of the lighting issues, I have checked all the bulbs, fuses and, wires, in the right rear light, I only have back up, and running lights, no brake or directional, up front right, I have no headlight(high or low) no directional but I do have running and hazards. On the front left, I have everything except directional. The left rear has everything, but when the right directional is activated, it binks 3 short times, and 1 long time. I hope you were able to follow all that, and I really hope you have an idea of where to start.
Wednesday, September 17th, 2008 AT 9:20 PM
2CARPRO JACK
  • 11,533 POSTS
Sounds like it may be a problem with the turn signal switch. Do you have power into the brake light switch and then out when pedal is pressed? Need to test (test light) for power into the headlight switch as well (red wire, orange wire) with key off and on
Thursday, September 18th, 2008 AT 7:39 AM
