1987 GMC Sierra Fuel problems
175,000 MILES • V8 • 4WD • MANUAL
BU113TZ
  • 7 POSTS
I cant get my truck running. Ive replaced the Fuel Filter,Fuel pump relay, Fuel selector valve, Oil pressure switch, Fuel tank Switch, MAP sensor. What should I do next
Dec 13, 2009 at 1:50 AM
  • 75,988 POSTS
When you turn key to run do you hear the fuel pump? if so check the fuel pressure with a gauge if its within specs and also for an injection pulses.
Dec 13, 2009 at 4:20 AM
BU113TZ
  • 7 POSTS
When i turn the key on I cant hear the pump come on but it has a fuel tank switch on the dash and you have to depress it full when switching tanks. And if I hold the switch down then turn the key on i can hear it prime but as soon as i release it the truck stops getting fuel
Dec 14, 2009 at 6:44 AM
  • 75,988 POSTS
Test the transfer switch
Dec 14, 2009 at 6:47 AM
BU113TZ
  • 7 POSTS
What is the transfer switch and how do you test it
Dec 16, 2009 at 2:33 AM
  • 75,988 POSTS
fuel tank switch same as the transfer switch-check and test the fuel pump relay. When you trun ket to run you should be able to hear the fuel pump come on for 2secs-its not happening
Dec 16, 2009 at 2:44 AM
BU113TZ
  • 7 POSTS
I can only hear it come on for a couple seconds when i hold the switch down and turn the key on but if im not holding it down it doesnt come on at all do you think both the fuel pumps are bad ????
Dec 16, 2009 at 10:17 AM
  • 75,988 POSTS
You need to determine which pump is coming on and its fuel pressure if its within specs
Dec 16, 2009 at 1:35 PM
BU113TZ
  • 7 POSTS
If i hold the switch on either side i can hear them come on but if i turn the key on without holding the switch down they dont come on at all I dont know if i have the switch wired up wrong or what
Dec 18, 2009 at 5:04 PM
  • 75,988 POSTS
Open up the switch and tell me how many wires are going to the switch
Dec 18, 2009 at 7:10 PM
BU113TZ
  • 7 POSTS
There are 4 wires going to the switch I have a test light and only 1 of the wires is hot and its only hot for a few seconds when i turn the key on.. none of the other 3 wires ever make the test light come on I think there is 1 black wire,1 red with white stripe, 1 solid red, and 1 grey wire, And the one wire that is hot for a few seconds is the red with white stripe..
Dec 18, 2009 at 11:17 PM
