2007 GMC Savana Change fuel filter reminder
CHEK
2007 GMC Savana
We changed the fuel filters and now cant reset the change fuel filter message. Can you help?
Feb 6, 2010 at 5:45 AM
BRIAN 1
  • 1,030 POSTS
FUEL FILTER LIFE RESET
This message will appear when a reset is performed either by using the steering wheel controls or the following manual procedure.
For vehicles with steering wheel controls, press and hold the select button for five seconds while the FUEL FILTER LIFE message is displayed. This message will appear on the DIC for ten seconds.
For vehicles without steering wheel controls, do the following:
Without pressing the pedals, turn the ignition key to the on position without starting the engine.
Wait five seconds.
Completely press the brake and the accelerator pedals simultaneously and hold for ten seconds. The system is now reset.
Turn the ignition key off.
The next time the engine is started, the message will no longer be displayed. Always reset the FUEL FILTER LIFE system after a fuel filter change.
all this info is in your owners manual.
Feb 6, 2010 at 10:33 AM
