2002 GMC Savana monitors not ready CA smog test
2002 GMC SAVANA
78,800 MILES • V8 • 2WD • AUTOMATIC
ALHARJ
  • 9 POSTS
vehicle passes emissions tests - no problem
failed the MIL/Check Engine Light due to failure to successfully complete all OBD self tests (monitors not ready - drive at least 80 freeway miles)
Dec 30, 2008 at 11:34 AM
JAMES W.
  • 2,394 POSTS
I'm not quite sure what your problem is. Do you not get a check engine light, or you have the CEL on, but get no codes? I need a little more info so I can help you. Please advise.
Dec 30, 2008 at 4:55 PM
ALHARJ
  • 9 POSTS
Passes ASM Emissions test: 25mph@1476 rpm; 13.8%-CO2, 0.5%-O2, HC-1 ppm, CO-0.00%, NO-0 ppm.
Fails Functional check (Malfunction Indicator Light-Fail)
Is there a procedure to reset the MONITORS?
I was told to drive 80 freeway miles then retest.
NO "Servce engine soon light"
Dec 31, 2008 at 10:15 AM
JAMES W.
  • 2,394 POSTS
When you turn the key to "on", not start, does the service engine light come on? Usually the monitors will reset themselves after 50 miles or 5 key on/key off cycles.
Dec 31, 2008 at 1:36 PM
ALHARJ
  • 9 POSTS
Key "on" only = NO "service engine soon light"
I don't have a OBD II monitor to check
Jan 1, 2009 at 7:27 AM
JAMES W.
  • 2,394 POSTS
Check the bulb in the dash for the CE light. If the bulb is good, I would say that circuit of your ECM is bad.
Jan 2, 2009 at 3:10 AM
ALHARJ
  • 9 POSTS
SES light - tests OK when key is initially turned on like other dash indicators. Drove some the other day, SES light is out but without a code checker I'm not able to know if everything is OK sensor-wise. Going back to Smog Check to find out Mon.
Jan 4, 2009 at 7:33 AM
JAMES W.
  • 2,394 POSTS
Let us know what you find.
Jan 4, 2009 at 11:23 PM
ALHARJ
  • 9 POSTS
ended at dealership to replace fuel tank evap. vent on tank. All "monitors" cleared, aced smog retest.
Jan 9, 2009 at 9:55 AM
JAMES W.
  • 2,394 POSTS
Glad to hear it. Anything else, you know where to find us.
Jan 9, 2009 at 11:56 AM
