2001 GMC Savana Rear Brake Drum Removal
2001 GMC SAVANA
75,000 MILES • V8 • 2WD • AUTOMATIC
BOB SCHNEID
What is the trick to removing the rear brake drum --Usually there is a small rubber plug to remove and back off a star wheel to release the shoe tension --Not so with this Van --Please help !!!
Jul 26, 2008 at 11:42 AM
MASTERTECHTIM
  • 4,750 POSTS
look real close and see if you see a spot where the rubber plug should be. you will see it outlined. smash that piece in with a hammer and screwdriver then unadjust shoes.
Jul 26, 2008 at 12:34 PM
