2001 GMC Savana COOLANT LEAKING FROM ENGINE BLOCK
130,000 MILES • V8 • 2WD • AUTOMATIC
AEARLE
COOLANT IS LEAKING OUT OF THE ENGINE AT THE HEAD GASKET.
IT DOES NOT LOOK LIKE THERE IS ANY WATER IN THE OIL.
WHAT IS THE RECOMMENDED REPAIRS ?
Sep 10, 2009 at 2:29 PM
  • 31,937 POSTS
Hi there,
if the coolant is leaking via the head gasket, there is a very good chance that is is or will soon be leaking internally as well, possibly into a combustion chamber, this will eventually lead to a fully blown head gasket, the only way to treat this problem is to have the heads removed crack tested surfaced and replace the head gaskets.
mark (mhpautos)
Sep 10, 2009 at 10:22 PM
