fuell gage is acting up moving around getting stuck in one position
Aug 6, 2009 at 1:13 AM
RACEFAN966
✓Experienced Mechanic
Ok so do you have a digital multi meter? If so and you feel comfortable enough then we can check the wire to the guage and see if there is power there as needed. If this is fine then we can check the guage and sender I do suspect it will probably be the fuel pump sending unit (it is a unit).
Aug 7, 2009 at 4:58 AM
