1997 GMC Savana starter
1997 GMC SAVANA
68,000 MILES • V8 • 2WD • AUTOMATIC
JAMESDOAN
After stopping for fuel, starter would not engage. Battery seemed to be hot and when attempted to jump off, the starter would still make no attempt to engage. The headlights do not dim when the ignition key is turned, so I'm guessing that it is either the starter, starter solenoid, or a safety switch. Where would be the best place to start checking? thanks
Jul 16, 2008 at 9:13 PM
2CARPRO JACK
  • 11,533 POSTS
Start by checking for 12 volts at the small starter wire when key is in crank position. If it has it, the starter is bad, if not get back to me and I will give you the next step......
Jul 17, 2008 at 12:41 AM
JAMESDOAN
Sorry about the delay, my computer junked your responce. I'm not the best on computers! There was no voltage on the small wire at the starter motor with the ignition start engaged, however, when I accidently shorted the terminal with the heavy battery lead, the starter motor bumped.
Jul 18, 2008 at 1:49 AM
JAMESDOAN
Upon further checking of the fuse panel, I found one labled crank. Fuse was not blown but since I had a spare, I replaced it and the starter engaged. There was no visible corrosion on the fuse, and the meter showed continuity through it. I guess eleven years had taken a toll on the connection, but the fuse panel has never even been opened up since it was purchased new. That didn't help atone for the $70.00 towing fee, but you win some, you lose some! Many thanks for the support!!
Jul 18, 2008 at 3:29 AM
2CARPRO JACK
  • 11,533 POSTS
No need to thank me, you found that one on your own.... good find. Sorry I didnt reply sooner, just got to checking my email..........
Jul 18, 2008 at 3:44 AM
