1997 GMC Savana Air conditioning compressor
1997 GMC SAVANA
98,000 MILES • V8 • 2WD • AUTOMATIC
RHAWKES6
How do I replace air conitioning compressor? Obviously it is located right at the top of the engine and easy to remove, but what should I do that I unique? Release the freon? etc.
Jan 13, 2008 at 8:49 AM
2CARPRO JACK
  • 11,533 POSTS
System is under pressure i cant recommend anybody other than an authorized/trained professional to evacuate the system. Once empty, the compressor needs to be drained of oil so the correct amount can be put back in the new comp and then the system needs to be vacuumed down to remove any contaminents and or moisture from the system
Jan 14, 2008 at 9:38 AM
