Van will not start
TEDDY
1992 Van V6, 156,000. Engine stopped while driving. Towed home. Replaced ignition coil, ignition module. Still won't start. Has fuel. Will crank, dashboard lights come on, doesn't spark. Help.
Jul 26, 2007 at 3:58 AM
CESAR LOMELI
  • 30 POSTS
check that the connections to the distributor are correct if thats ok then check your rotor turns when you crank the engine if it does then its probobly its going to be your timing belt
Jan 14, 2008 at 1:15 PM
