I tried to adjust this by loosening the post with a torx and slide it down slightly but I found out that the hole which the post screws into is real tight and does not allow for any up/down adjustment. I was always able to do the adjusting in other vehicles but this one got me.
I could make the hole oblong with a file but I am afraid to unscrew the post completely in fear of dropping the nut down inside of the door frame. Any suggestions?
thanks
SPONSORED LINKS
Wednesday, February 18th, 2009 AT 10:27 AM
