2002 GMC Safari no heat when switch is turned on
2002 GMC SAFARI
35,000 MILES • 6 CYL • 2WD • AUTOMATIC
ZUCK
hoses are hot ,radiator is fine looking for sensor that contols the opening & closing of the hot water
Oct 2, 2010 at 10:35 AM
TWINCIRCUITS
  • 8 POSTS
I have a 1995 Safari and maybe it's about the same... The heater hose comes up to a valve on mine that is controlled by a vacume line. However on mine the valve itself broke off in the shut position and caused this same type of issue. The only time it would get the leaset warm is when I was sitting still. I replaced the valve itself and that solved the problem. Had to go to a GM dealer and order the part....
Dec 23, 2010 at 3:06 AM
