My car gets no heat unless I am traveling at high speeds for about 10 min. My temp Gauge reads high 235, once the van runs for a while but does not overheat or change performance. I changed the thermostat, but still no change, I was told it could be my water pump, or my heater core is cloged. I see no leaks under van overnight. Also, coolant in reservour doesnt change much when van is hot. What do you think it could be?
SPONSORED LINKS
Sunday, January 10th, 2010 AT 3:58 PM
