2002 GMC Safari Front Brake Pad and Rotor replacement
150,000 MILES • 6 CYL • AWD • AUTOMATIC
TBERC
On 2002 GMC Safari Van - is the front disk brake caliper actually a piece of the entire wheel assembly and not independently removable? In other words, does it need to be replaced by a professional shop vs. me at home?
Feb 3, 2010 at 11:48 AM
BLUELIGHTNIN6
  • 16,542 POSTS
The front disc brake caliper on your Safari can be replaced as a separate unit, would you like replacement steps?
Feb 3, 2010 at 12:44 PM
TBERC
I really just want to replace the pads and rotor, but can't remove the whole wheel assembly if that's what's needed. Can I replace pads and rotor without removing entire assembly on 2002 safari?
Feb 4, 2010 at 5:43 AM
BLUELIGHTNIN6
  • 16,542 POSTS
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_1588.jpg
https://images.2carpros.com/forum/automotive_pictures/261618_Noname2_485.jpg
https://images.2carpros.com/forum/automotive_pictures/261618_Noname3_182.jpg
Feb 4, 2010 at 7:41 AM
ANTHONYDEBELLIS
Hello I cannot loosen the caliper pins, they are torx, I have the appropriate socket but they will not loosen, I used my c clamp to push in the pistons successfully. please help,I tried liquid wrench/wd 40 aand also a propane torch, wont budge,any tips?, Thanks, Anthony
Sep 30, 2012 at 2:45 PM
