2001 GMC Safari AC Blower
140,000 MILES • 6 CYL • 2WD • AUTOMATIC
KONABLUE
My 2001 Safari seems to only want to blow air out of the defrost ducts no matter the setting that the switch is on. I have checked the AC relay and fuses in the fuse box under the hood.
Dec 8, 2009 at 5:48 AM
  • 75,988 POSTS
Could be one of the following air mix/blend/mode door problems, vacuum/actuator and HVAC control module.
Dec 8, 2009 at 7:10 AM
WEEKENDWRENCHER
Had same problem with 2000 GMC Safari. Don't know your situation, but mine was missing a vacuum hose. Right now the damper is back to the -default mode- if you will , so your windshield can still be cleared. What I had to do was take off the inside motor cover and all components under dash (not reall that hard just time consuming). The missing vacuum line went into the engine by the drivers side near the middle of engine, off the pcv valve. Now from there it went to the front (under hood) to a tee fitting. Then from there one went down to canister, the other into van. Total cost was near 10 bucks for new hose 5/32 was size I used. Any other Q's and hpefully this helps- Goodluck
Dec 8, 2009 at 12:04 PM
