2000 GMC Safari When Hot outside and AC running engine will
120,000 MILES • 6 CYL • 2WD • AUTOMATIC
JCUTRIG
  • 6 POSTS
When it is hot outside about 85 and we run the AC the van will slowly stop accelerating, starts off anything past 3/4 throttle and 1/2 and then anything other then an idle. After it cools down it runs fine again. This never happens in the cooler months. I have seen it happen when very hot outside even with the AC off, 95+.
I have a OBD2 software program that show an Fuel systems status or Open Fault when this occurs
I have jut replaced both the O2 sensors and the fuel filter and this did not resolve the issue.
Any ideas?
Aug 4, 2009 at 5:17 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Would you post the codes in POxxx format
Thank You
Aug 5, 2009 at 12:57 AM
JCUTRIG
  • 6 POSTS
I have a text file with the codes I am using a software product called OBD2.com
Aug 5, 2009 at 2:45 AM
DOCFIXIT
  • 18,828 POSTS
Is Check engine light on? if yes can you get to an Auto Zone and have codes read. If no check fuel pressure cold and engine hot.
Aug 5, 2009 at 4:00 AM
JCUTRIG
  • 6 POSTS
[quote:f7277256d7="Docfixit"]Hi
Thank You[/quote:f7277256d7]
I have attached a live capture of what is going on when the issue happens the items in yellow are showing exactly when it happens
I also attached a dump of the codes but these are before I replaced the O2 sensors and the codes have been cleared and do not come back even when the issue happens.
Aug 6, 2009 at 5:26 AM
JCUTRIG
  • 6 POSTS
I can not figure out how to attach a file to the post how do I do that?
Aug 6, 2009 at 5:29 AM
JCUTRIG
  • 6 POSTS
I just pasted them into this post but again these are before I replaced the O2 sensors and not I dont get these codes. But the issue still happens
Stored Codes
P0113 16
P0113 Intake Air Temperature Sensor 1 Circuit High Input
P0171 16
P0171 System Too Lean (Bank 1)
P0300 16
P0300 Random/Multiple Cylinder Misfire Detected
P1870 16
--- End of list ---
Pending Codes
P0131 16
P0131 O2 Circuit Low Voltage (Bank 1, Sensor 1)
P0151 16
P0151 O2 Circuit Low Voltage (Bank 2, Sensor 1)
P0300 16
Aug 6, 2009 at 5:30 AM
DOCFIXIT
  • 18,828 POSTS
Check fuel pressure 60-66psi misfire and lean condition generaly caused by low fuel presure.
Aug 6, 2009 at 5:38 AM
JCUTRIG
  • 6 POSTS
Ok I will check that today.
Can you help me understand why fule pressure might drop when the outside temp is above 85 and the AC is on?
Thanks
John C
Aug 6, 2009 at 6:07 AM
