2000 GMC Safari rear axle
2000 GMC SAFARI
140,000 MILES • 6 CYL • 2WD • AUTOMATIC
JSINGS42
  • 8 POSTS
which side is the drive axle on a 2000 safari. Tyhe driveshaft and universal joint turn the gears in the differential turn but the wheels don't turn. I do hear some noise in left wheel. Is that the side that the van go?
Jan 7, 2008 at 6:50 AM
MASTERTECHTIM
  • 4,750 POSTS
most likely the spider gears broke inside. to break anything else you would have had to go over a 60 foot jump
Jan 7, 2008 at 7:11 AM
JSINGS42
  • 8 POSTS
I opened the Differential and observed that all the gears inside turn when the van is placed in reverse or drive. I can hear noise from the left wheel. does that mean it could be the axle or does it still indicate the spider gear?
Jan 7, 2008 at 2:19 PM
MASTERTECHTIM
  • 4,750 POSTS
ive never in my life seen a axle break. look closely inside the center piece of rear end you will see 4 smaller gears, the axle might have stripped inside one of the side gears.
Jan 8, 2008 at 12:18 AM
