2000 GMC Safari rear axle
JSINGS42
  • 2000 GMC SAFARI
  • 6 CYL
  • 140,000 MILES
Which side is the drive axle on a 2000 safari. Tyhe driveshaft and universal joint turn the gears in the differential turn but the wheels don't turn. I do hear some noise in left wheel. Is that the side that the van go?
Monday, January 7th, 2008 AT 2:50 PM
MASTERTECHTIM
  • 4,750 POSTS
Most likely the spider gears broke inside. To break anything else you would have had to go over a 60 foot jump
Monday, January 7th, 2008 AT 3:11 PM
JSINGS42
  • 8 POSTS
I opened the Differential and observed that all the gears inside turn when the van is placed in reverse or drive. I can hear noise from the left wheel. Does that mean it could be the axle or does it still indicate the spider gear?
Monday, January 7th, 2008 AT 10:19 PM
MASTERTECHTIM
  • 4,750 POSTS
Ive never in my life seen a axle break. Look closely inside the center piece of rear end you will see 4 smaller gears, the axle might have stripped inside one of the side gears.
Tuesday, January 8th, 2008 AT 8:18 AM
