2000 GMC Safari Misfire when when engine is cold in morning
2000 GMC SAFARI
145,000 MILES • 6 CYL • 2WD • AUTOMATIC
JAKRO1972
  • 5 POSTS
I noticed since the rainy season started here in Florida that my engine will misfire or hesitate a little before the engine is completely warmed up and it only seems to happen early in the morning. I'm thinking that something is damp with the morning condensation, maybe the plug wires are shorting out across the block or against each other and need replacement. The problem doesn't exist any other time of day or night, just early morning. The plugs are fairly new and the cap and rotor are new. Wires might be original.
May 31, 2009 at 5:16 PM
JAKRO1972
  • 5 POSTS
I've replaced Plugs, Wires, cap and rotor but still get a misfire at around 1000 rpms before the engine reaches 187 F and then the misfires diminish. The computer shows a random misfire code but does not set the light on. Any clues as to what is causing this every morning?
Jun 27, 2009 at 4:06 AM
