My van wont start whenever the air is damp?
140,000 MILES • 6 CYL • 2WD • AUTOMATIC
CBINTEGRA
  • 6 POSTS
My van wont start whenever the air is damp. I have replaced the spark plugs and wires, rotor, dist. cap and the mass air flow sensor. Do you have ideas on what else I can check. No codes show sense it hasnt started when it is having the problem. On dry days it starts right up and runs good.
Mar 17, 2010 at 10:45 AM
DOCFIXIT
  • 18,828 POSTS
Hi Try this on dry day engine starting get a spray bottle with water. Spray then Ignition Control Module they try and start if starts do same to crankshaft sensor. See diagrams
https://images.2carpros.com/forum/automotive_pictures/198357_Graphic_405.jpg
https://images.2carpros.com/forum/automotive_pictures/198357_Grafic_3_107.jpg
Let me know Thanks for donate
Mar 18, 2010 at 5:30 AM
CBINTEGRA
  • 6 POSTS
Thanks alot, man! You probably saved me hundreds that a mechanic would have charged. I sprayed water on the crankshaft sensor on a dry day like you advised and it didn't start...put a new one on and sprayed it and it started right up. The real test will be in a few hours when it rains, but I'm pretty sure that fixed it. You know what you're doing! Thanks again.
Mar 21, 2010 at 5:27 AM
DOCFIXIT
  • 18,828 POSTS
Glad to have helped Yea could have turned into a Money Pit. Come back if you need help in the future
Mar 22, 2010 at 1:05 AM
CBINTEGRA
  • 6 POSTS
I was wrong...it is raining today and the van would not start again. The only thing I havent replaced is the ignition control module...any other ideas?
Mar 22, 2010 at 8:01 AM
DOCFIXIT
  • 18,828 POSTS
Check out vehicle control module left side engine compartment. See if rain water getting on VCM. pull connectors see if its wet.
Mar 23, 2010 at 8:26 AM
CBINTEGRA
  • 6 POSTS
I checked out everything i could see without taking it apart..nothing seemed wet..i give up..taking it to a mechanic tomorrow..thanks anyway
Mar 23, 2010 at 10:32 AM
TUFFBLU50
I had this problem for years and understand so did GMC trucks.
Somewhere in this period around 2000, GMC went to a low profile distributor.
After a zillion mechanic in several states and a lot of $$$ later I finally found a mechanic who figured it out and a solution.
What he did was put dialectic grease all around distributor. Then he saw that air conditioning lines went directly over the distributor causing condensation so he split a garden hose which he covered the lines with.
I have not had any problems since and that was about 4+ years ago.
Hope this helps
Sep 14, 2022 at 4:17 AM
  • 55,694 POSTS
Excellent addition to this thread! Please feel free to use 2CarPros anytime!
Sep 14, 2022 at 4:51 AM
