1999 GMC Safari window switch
48,000 MILES • 4 CYL • AWD • AUTOMATIC
ODIEONE21
The drivers side window worked most of the time but occasionally after putting down it won;t go up. If I shut off the motor and wait a couple of minutes then try again it works. What causes this?
Dec 2, 2008 at 10:52 AM
MASTERTECHTIM
  • 4,750 POSTS
this is usually caused by a overheated window motor and if not used it will cool and reset itself then work again until it overheats again
Dec 2, 2008 at 10:57 AM
ODIEONE21
Thanks. So I guess that means the motor is shot or is there something else that could be causing it to over heat?
Dec 3, 2008 at 3:50 AM
MASTERTECHTIM
  • 4,750 POSTS
99 percent of the time its a bad motor
Dec 4, 2008 at 12:27 PM
