[quote:9ee7d020b9="jwinner1"]Brakes problem
1999 GMC Safari 6 cyl Two Wheel Drive Automatic 140900 miles
how do i remove and replace brake rotors on a 1999 gmc safari[/quote:9ee7d020b9]
remove wheel, remove brakes by two hex head bolts. Remove bearing cap, the cap in the center of the rotor,remove carter pin. Remove lock washer and remove nut. Pull off rotor and knock out seals and bearings. install reverse of removal.
Dec 1, 2009 at 5:17 PM
