1999 GMC Safari muliple cylinder misfire
130,000 MILES • 6 CYL • 2WD • AUTOMATIC
SAFARI WILL
encountering muliple mioss firing trouble starting
Nov 3, 2010 at 2:36 PM
  • 75,988 POSTS
Engine running rough or misfiring can be cause by the following:
1.Defective spark plug
2.Inadequate spark/coil,defective spark plug wire.
3.Lack of compression
4.False air leakage.
5.Faulty fuel injectors.
6.Insufficient fuel pressure.
7.Contaminated fuel.
8.EGR valve that is leaking.
9.Oxygen sensors.
10.Throttle position sensor.
11.Manifold absolute pressure sensor
Nov 3, 2010 at 8:54 PM
